Network problems in RH16 for 4 days now
miketja
I've had no mobile service in or around home for 4 days. No issues elsewhere when I'm out and about further afield, and the status check confirms there's a fault in my area. The question is: how can I get an update on when the fault is likely to be fixed? There's zero information provided on the status website that I can find, just a "we'll message when it's fixed" statement. Not very helpful. Is it going to be another day or two? A week? A month?  Getting a fix estimate will help me decide if I should buy eSIMs for myself and my family, on another network, to keep us all going in the meantime. Thanks.
Sounds like you've done the right thing in using the online status checker - this provides a best estimate of fix times based on numerous criteria, but to provide a guaranteed resolution time is impossible.
The vast majority of radio faults are rectified in a few days.
