Network problem
Shah55
Does any one has the same issue like with me , my we network has no service in y house but working properly outside my house . I check the network operated and they confirm the coverage is fine in my area
Northerner
Hi @Shah55
It depends on your device, where you are in the house, construction, other devices, distance from the mast etc...as to if you'll receive a signal.
Can you connect to WiFi calling?
Is this a recent problem? It's common for there to be reduced coverage inside buildings than outside - WiFi-calling is the recommended solution where this is a problem.
