Network has been down
Michael278
My network has been down for over a month now were I get no signal on my phone and when I check it says it’s going to be 18 hours until fixed but that was a month ago
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker  in the first instance, to check for local service outages. The "report a problem" link should be used if no issues are reported but EE users continue to have issues. The wider an area or the longer a timescale that you're without coverage, tends to point towards a phone issue rather than a network one.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
