NO SIGNAL AVAILABLE LS8 ***
IKB1
CONTINUALLY SEEING NO SIGNAL AVAILABLE..... CANNOT DIAL ANY NUMBER.
[Mod edit: removed personal details]
@IKB1 wrote:
I am on SPUSU
In which case you should contact Spusu with any or all service enquiries. It is they who provide your service.
The EE status checker I linked to earlier, is only available to EE-direct subscribers also.
6 REPLIES 6
Posting in all capitals on the internet is widely regarded as shouting and thus rude, please check your caps lock.
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker  in the first instance, to check for local service outages. The "report a problem" link should be used if no issues are reported but EE users continue to have issues.A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
Thanks for your info.
Sorry about caps lock, but I have poor eyesight and caps do assist.
Post Scriptum. "you can use WiFi-calling"    WiFi calling is not available on my 'phone.
Northerner
Hi @IKB1
What device do you have. (Manufacturer, model).
Are you on EE PAYG or pay monthly contract.
I am on SPUSU. they use E.E.
'Phone is circa 7 Yrs. old.
I have dual SIM, other SIM is on O2, no problem with O2
@IKB1 wrote:
I am on SPUSU
