10-11-2023 04:24 PM
I have the IPad Pro 2022 , when leave it for a few hours and then go to use it there is no internet connection, just a spinning wheel . I turn it off and back on and it’s back to normal, just a bit annoying.
14-11-2023 05:00 PM
10-11-2023 05:17 PM
Hi @Johngee8
Tried activating flight mode and then reactivating.
11-11-2023 06:20 PM
Do you have an EE mobile, and if so, is this similarly affected?
11-11-2023 09:03 PM
14-11-2023 12:32 PM
Tried it, same problem.
14-11-2023 01:28 PM
If the phone doesn't have the same issue, that suggests an issue with the tablet itself - although a 2way SIM-swap between the two devices would prove that categorically.
I'm unfamiliar with iOS, but I'd be minded to check the power-saving options as a next step.
14-11-2023 05:00 PM
21-11-2023 12:23 PM
Still the same
21-11-2023 12:40 PM
Hi @Johngee8
Please get back in touch with our technical support team who will continue the troubleshooting to let you know what is needed for the signal dropping on the iPad.
Leanne 🙂
