Location notification
Katiebob
Hi all,
Getting the below when I try and do the lottery. Any ideas on how to fix it?
TIA
cepenpark
You need to allow the lottery site to see your IP address. Tap the square like symbol to left of the web address, tap the 3 dots to show settings and tap Show IP Address.
7 REPLIES 7
cepenpark
Northerner
Hi @Katiebob
  1. Are you in the UK
  2. Are you using or is the browser using a VPN.
@cepenpark  not true at all.  I don’t have that enabled , I use a VPN and I use iCloud private relay.
 All I get is, ( image below) and I click I’m in the UK and I get access.
@Katiebob  Do you have that issue if using the lottery app ?
Katiebob
@cepenpark - this worked - thank you!
thanks all. Solved.
Leanne_T
Hi @Katiebob
Thanks for coming back and letting us know the advice from @cepenpark has resolved this for you.
Have a great weekend.
@Katiebob  You have a work around it’s not actually resolved the issue.   See my comments above.    Happy you’ve a working solution all be it with IP address tracking.  Your right to privacy doesn’t mean you should be sharing your IP address.
