27-08-2025 04:40 PM
Is anyone else suffering from no data around L13 or is it just me ?
27-08-2025 04:43 PM
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker in the first instance, to check for local service outages. The "report a problem" link should be used if no issues are reported but EE users continue to have issues.A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
27-08-2025 04:43 PM
