Issues with phonecalls
TMV1
I have my wifi calling on everytime I am on the phone to someone there will be a point in the call where the line goes quite. Then it will come back into the call I also find it will hang up on people and I can’t understand what’s wrong with my phone can anyone help me understand please it’s driving me mad!
14 REPLIES 14
@TMV1   It’s possible your device is changing from WiFi calling to cellular call at that time it goes quiet.  It’s very possible that it could also drop the line when this happens as the device didn’t actually make that connection so just lost signal.
So is there a fix for this I had to put wifi calling on as my ee signal is shocking where I live
Sent from Outlook for iOS<>
Is this audio problem something that's only started recently?
It may be worth monitoring your phone's signal indicators when this happens, to see whether WiFi-calling or 4G-calling is active when this happens, or whether it is being caused by a handover between the two.
If calls are dropping unexpectedly, the same test will be useful.
It doesn't state when I’m on call whether it is on wifi calling or 4G. It’s an ongoing thing not been able to get hold of ee today to speak to anyone hence why I’m on this chat thing they advised me to put on ee calling last time it makes no difference really.
Android phones do have an onscreen indicator between 4G-calling (VoLTE) and WiFi-calling, I believe Apple is similar but I don't use it.
Any troubleshooting could be assisted by an estimate on when this problem started.
Northerner
Hi @TMV1
If you have an iphone this is normal. I can be using wifi calling and then the call goes dead as it might catch a network signal, that's it the call is gone. Iphone wifi to network transfer is rubbish and its at the point now i use teams calls (this is my works iPhone) over WiFi calling.
On Android this isnt a problem as you can select the priority wifi over network. No issues.
I’ve switched that off this week to see what happens and still get the same issues everyone saying my network is rubbish lol
Leanne_T
Hi @TMV1
Does this happen in more than one area?
Are you able to try the SIM card in another phone to see if the same happens?
Leanne 🙂
Hello,
This is predominantly at home. I can try another phone but not sure if it will do the same.
thanks
