Is EE having an outage in Peterborough
wyedwardchan
I basically should have a 3 bars 5G signal or a full 4G signal inside my office, while today I've got no 5G signal and 1-2 bars of 4G which basically can't go into any app that require data usage.
So basically, is EE having a problem here or is it just me suddenly suffering from this?
@wyedwardchan   Have a look at THIS fill it out with the postcode and your device and then click the check status tab.
