“I’m sorry. Calls are not currently being connected to this number”
Fat-Veg
Got a weird one here.
about 50% of the time when I call my wife I get this message.
No one else who calls her gets it and I don’t get it when calling anyone else.
no account or billing issues.
There was apparently  a problem with local mast but it happens even when we are both in a totally different place together, well out of the range of that mast.
what could it be? Both running iPhones, the only difference is I have an eSim
Leanne_T
Hi @Fat-Veg
Does your Wife's phone show full signal when this happens?
Are you both connected to WiFi or using the EE network when you get this message?
Thanks 🙂
Hi there
it happens regardless of whether WiFi calling is on or not unfortunately.
cell signal is low (2 or 3 bars) yet other calls come through fine.
Does caller ID (or lack of) make any difference?
How about if you disable 4G & WiFi-calling to force your calls to go over 2G/3G? I wouldn't recommend it as a permanent change, but it's a perfectly valid diagnostic check.
Weirdly that worked.... but not a permanent fix, what does this mean? Is it a handset issue?
Which suggestion worked? Not sending CLI, or disabling 4G?
And if you disabled 4G & WiFi, was this on the calling phone or the recipient phone?
