I have no mobile signal for a week now
nickyimrie24
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker  in the first instance, to check for local service outages. A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
Katie_J
Hello @nickyimrie24, @myaconnors and @Grant31.
Do you receive signal in other locations OK?
Have you been able to check the Status Checker that has been linked by @bristolian?
Katie
