06-03-2023 12:48 PM
Hey,
I would like to know if its possible to send a voicemail to a phone number on the EE network? This is a work call I want to make but the manager may be unavailable so is it possible to just send a voice mail without phoning in?
Its OK if there isn't, just a question? SMARTY has this feature but it was next to useless, it hardly worked anyway.
06-03-2023 02:04 PM
You can do this by calling your EE voicemail, following (from memory) option 3 then option 5.
06-03-2023 02:04 PM
06-03-2023 03:59 PM
Hi @bristolian,
You got that bang on so thanks for the info. 😊
Just when you've entered a phone number and after it's read back to you, press 2 and then the # key to save and send the message you want.
