Emergency calls only
Argylefan21
On the Isle of Wight got up this morning phone says emergency calls only,  I took sim out and put it back  , I turned phone off and on  , I turned airplane mode on and off  , even on wi fi calling it says no service no connection but it is connected to the wi fi . I'm housebound so phone is my lifeline.  It's contract not payg have checked what providers are available just says 02 and Vodafone doesn't say ee .
Katie_B
Hi @Argylefan21
Welcome to the community.
Are you aware of anyone else experiencing this in your area?
Do you have another device you can test your SIM in?
Speak soon,
Katie
Try making a call with WiFi-calling enabled. Are you able to make a call?
Your network search shows a lack of EE coverage where you are - whether through fault or no-service area. The "check status" option on https://ee.co.uk/help/mobile-coverage-checker hopefully lists this. If not, use "report a problem" in the meantime.
