Emergency calls only
Maggieerskine
I have been using same sim card for years but suddenly started saying emergency calls only. Please help
Sounds like your PAYG SIM may have gone into hibernation due to non-use.
When did you previously make a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months period of grace to call EE to reactivate it before it is lost completely.
Is it on contract or PAYG?
PAYG
