22-11-2023 04:47 PM
22-11-2023 05:19 PM
Does your phone have coverage indicators showing?
If not, select "check status" on https://coverage.ee.co.uk/coverage/ee
22-11-2023 07:42 PM
Yes he does and my data is working perfectly
22-11-2023 08:25 PM
That rules out a coverage issue. What happens when someone calls you, both on your phone and that of the callers?
Can you make outgoing calls OK? Have you inadvertently set a "do not disturb" mode?
