EE signal
Dariusz24
I have  similar experience, and same with ee from their beginning, signal ee are hopless,fortunately new phones have dual sim card  "pocket" and even cheap phone provider are 1000% better then ee.
this will be my last year with them,had enough
Leanne_T
Hi @Dariusz24
If you are experiencing signal issues is this happening in all areas or one particular location?
Have you reported the signal on the Service Status Checker?  once reported the network team will get this looked into and keep you updated.
Leanne 🙂
