EE Coverage and network status checker
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-04-2023 03:14 AM
No idea on the "Select Location" but the EE Coverage and network status checker says "You won't get 5G coverage on your 4G Hub". Who is being stupid here?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-04-2023 05:21 AM
@midee wrote - Who is being stupid here?
Well, if your checking your 4G Coverage on the EE Map, and its telling you "You won't get 5G coverage on your 4G Hub" then you must of selected the 5G Coverage Area option instead of 4G?
So, to check the 4G Coverage on your 4G Hub, then you need to select the 4G Option on the Coverage Map.
To Check the actual Coverage, select your Area (Post Code), select your Device, or an equivalent Device or Model, then select the Coverage option, tis should display your 4G Coverage for your Area, if you then select the 5G Map Area, and yur Device is not a 5G Device, the Map will confirm that you will tell you "You won't get 5G coverage on your XXX Device" whether you are in, or out of, a 5G Signal Area.
- Very disappointed in Mobile Network discussions
- Dear EE.. People can’t hear us when we make calls.. please fix in Mobile Network discussions
- Very weak/no signal in AL5 for 24 hours. in Mobile Network discussions
- SE25 continues to have bad connection in Mobile Network discussions
- Mobile data signal in Mobile Data
