Doro 730x setup
noisemonkey
I'm trying to set this up but it doesn't allow me to connect to the EE network.  It's a new unlocked phone I bought from Amazon and the APN settings appear to come from the sim card.  Any ideas why this wouldn't work?  The error says can't connect to the network at the moment try later
7 REPLIES 7
Jon_K
Former EE Employee
Hi @noisemonkey
Are you able to try and select the network manually in settings rather than automatically?
Has this phone worked with another SIM or is this the first time using it?
Jon
It's the first time using it and I don't have another sim to try. I tried manually selecting the network and get the same message
Leanne_T
Hi @noisemonkey
Thanks for coming back to us.
Is this a new EE SIM card?
Speak soon.
Yes it is
Leanne_T
Thanks @noisemonkey
Where did you purchase the SIM card?
noisemonkey
Direct from EE
Leanne_T
Thanks @noisemonkey
The SIM should be registered and ready to go for you, are you able to visit an EE Store to see if they can check the SIM card in another phone for you?
