Data connectivity in Windsor Berkshire
LWH
i live in Windsor and have huge issues with data connectivity. In the centre of town and back at home, inside and outside.
I went into store to ask for help and unfortunately was just sold to. My wife’s uses another provider and they don’t have the same problem. I have to constantly sign into Wi-Fi to use data.
what can we done to help?
13 REPLIES 13
@LWH  Wi-Fi has nothing to do with cellular data they are 2 different ways of having a data connection on a device.
Is this a Wi-Fi connection issue or a cellular data issue?
Wi-Fi is a connection to a router that provides a broadband internet connection.   This is the Wi-Fi symbol on your device and look similar to
Cellular data is using your device to connect to the EE network.
a different network is a different network so that has nothing todo with the connection on your device.
Thanks for the reply Chris.
it’s a cellular issue. I simply have no data access even though coverage is good.
I mentioned WiFi as the only way in an use data is to sign into hotspots.
Jon_K
Former EE Employee
Hi @LWH.
Have you had a look at our Network Coverage And Status Checker to see if there are any issues in your area?
Jon
Does your phone show VoLTE/4G-call when you have data issues?
It may be that you're inadvertently using 2G/3G
LWH
Thanks Jon_K
yes I have checked this. The status checker says it’s fine but unfortunately I still have the same issue.
in store they said that Windsor castle has had some EE signal “blockers” installed. Is this a thing?
Good thought thank you. But nope I have the 4G status and what looks to be decent coverage.
Christopher_G
I haven't heard of that before, @LWH
If you report a problem on that status checker, our Network Team will investigate it for you.
That can safely be filed under well-meaning but over-exuberant.
Are you able to use mobile data in other locations, or is it only Windsor town centre?
wootsno1
I can never use mobile data in Windsor this has been the case for many years now. I visit Windsor sometimes but it never allows me to use the Internet even with 4 or 5 bars of signal
