Coverage
ATUTA07
 Hello, what is your range in Spalding, whether it is very good and whether it has 5g and what is the best fare in the offer of e Sim
You can check coverage in any location of the UK via the coverage webtool
https://ee.co.uk/help/mobile-coverage-checker
6 REPLIES 6
@ATUTA07  If you want to use an eSIM you’ll need to be a contract customer.  Just look and see what you want to pay.  Do you want that to be sim only ? Or a full device contract
 so I checked and it shows that there is a great range but later it turns out that there is not a single line of coverage in my apartment
 I do not want to be bound by a contract for a year or two years, I prefer the option of a card because I can resign at any time if I am not satisfied with the range
Ali_A
HI @ATUTA07
We have a range of 1-month SIM only plans at Pay Monthly SIM only Deals | EE that you can choose from, so you're not tied into a long contract.
Just click the tag that says "24 months" to change the list to show the 1 month deals.
Once you're happy with the coverage where you need it, you can then upgrade it to 2-year contract for a better deal.
Ali
@ATUTA07 , if you have fixed broadband, you can use wifi calling on your phone, which will work the same as cellular, if the coverage is not very good indoors.
