21-08-2023
02:50 PM
- last edited on
21-08-2023
03:02 PM
DanielPA
I am having issues being heard on calls. Is there an issue or has some setting changed that I need to look at?
[Mod edit: Please do not post personal information on the public board. Thanks!]
21-08-2023 03:28 PM
I'd recommend checking for problems in your area using the Network & Coverage Tool.
Put in your postcode and choose your phone model, then click 'Check Status' to see if there are any issues in your area.
Has this only started happening recently?
Thanks,
Alex
21-08-2023 03:09 PM
What's the issue you're having with outgoing audio?
And is the issue location-specific?
21-08-2023 03:28 PM
Thanks,
Alex
24-08-2023 04:37 AM
There had been some maintenance activity, however, despite numerous power down and restarts, I tried it again and jissue resolved! Bizarre.
24-08-2023 04:37 AM
24-08-2023 07:54 AM
