05-05-2023 08:42 PM
Are there any EE customer service managers on here?
05-05-2023 08:47 PM
This is a user discussion forum, what's the nature of your query?
09-05-2023 06:34 PM
I’ve had unusable service since mid November, just wondering how long it normally takes to fix a mast?
10-05-2023 07:55 AM
Hi @Mcfc8575,
What does the Network Status Checker report for you area? (Select the 'check status' option)
10-05-2023
07:59 AM
- last edited on
10-05-2023
08:00 AM
James_B
Ee customer service say it’s been ongoing since June last year with 2 of the masts that are close to me having major issues, I’ve been with them over 25 years with very few problems if any. The postcode is
[Mod edit: Please do not post your postcode in this public forum. Thanks]
10-05-2023 08:02 AM
Hi @Mcfc8575,
If you enter you postcode into the Network Status Checker it should show the latest information for any issues in your area. You can also register for text updates so we can keep you informed.
Hope this helps.
