12-11-2026 11:52 AM
My Samsung Galaxy A17 worked very well connected via my home wifi until i had a software update last week. Before forgetting it i would just get 'connection failure' after three attempts. However, i can connect to EE WiFi using my EE.CO.UK website username and password.
My question is ---> on my phones list of "Available Networks" as well as seeing my hone network and others nearby. What is "EE WIFI" exactly. Does EE have a UK wide WIFI network or is it something else?
Any advice Welcome
12-11-2026 01:38 PM - edited 12-11-2026 01:41 PM
@candnwillis The help below.
https://ee-wifi.ee.co.uk/public/ee/help/index.htm
https://ee.co.uk/help/mobile/manage-use/using-phone-features/use-ee-wifi
https://ee.co.uk/help/mobile/manage-use/using-phone-features/how-do-i-access-wifi-coverage-boost
https://community.ee.co.uk/t5/Broadband-Landline/Opt-Out-EE-Public-WiFi/m-p/1623144
You can use the Hotspot feature, first part off a postcode will show you businesses transmitting,
All the postcode will show you potential homes that you can get onto as you type the full postcode into the entry box. Use the Find a Hotspot 1st link.
12-11-2026 12:05 PM
Hi there!
"EE WiFi" or "EE WiFi" hotspots are placed around locally in city areas for free access to the internet if either you are a BT broadband customer, EE broadband customer or BT business broadband customer. They are completely free as long as you sign into your billing account, otherwise to gain access you normally have to pay by the hour
There is also a option on EE home routers to add a guest network which then displays as this too
12-11-2026 12:56 PM - edited 12-11-2026 01:04 PM
12-11-2026 01:00 PM
@Fin02 wrote:There is also a option on EE home routers to add a guest network which then displays as this too
No, the Guest Wifi doesn't display as EE WiFi too. By default its SSID is "MainSSID-Guest".
12-11-2026 01:12 PM
@candnwillis The EE WIFI on your home Hub is the FREE for any EE customer to connect to and use.
12-11-2026 01:22 PM
Whilst trying to sort this out i have been connecting to the hotspots using my EE.CO.UK credentials'. So far its working fine.
I have managed to set up our routers guest Wi-Fi with security and a password which i can reconnect to automatically as an interim measure . I am hoping this is the route to take for a permanent solution.
12-11-2026 01:27 PM
If the Guest SSID works OK, so should the Main SSID.
12-11-2026 01:27 PM
@candnwillis Check your EE app version on the mobile, the most upto date fixed a few issues.
12-11-2026 01:30 PM
Thanks for the hotspot info. They were working quite well for me.
As a better temporary measure i have set up the guest Wi-Fi. That may lead me to a solution.
Thx again
12-11-2026 01:33 PM
The guest wifi displays with and ending" _GUEST" to you own routers name. I am using the guest router ad mu next interim solution.
