5G not working
paul-cording-dd
My phone is 5G compatible and I have a 5G contract but I cannot get 5G to work on my phone, any suggestions please?
In order to use 5G services - you need a 5G-compatible phone, on a 5G-plan, and to be in a 5G coverage area.
Have you checked the coverage in your area using https://coverage.ee.co.uk/coverage/ee ?
9 REPLIES 9
Devang17
I have Same problem
Leanne_T
Hi @Devang17
Thanks for coming here.
Do you have a 5G plan and 5G ready phone?
Does the EE Coverage & Network Status Checker | Check your signal show 5G is available in the area?
Yes for the 3 questions
Leanne_T
Hi @aamaaeg
Have you been able to use 5G previously?
Which phone are you using?
Leanne 🙂
Worked very occasionally in the beginning
iPhone 14 pro max
Leanne_T
Thanks @aamaaeg
Does this affect your service on the iPhone?
Is this in more than one area and 5G is available?
Andi123
I also have this problem with iPhone 14 pro max. 5G is useless.
Katie_J
Hi @Andi123.
Are you within an area that has 5G available?
This can be checked using the Network Status Checker.
Katie
