2 Masts
ch1121
Why are there two masts located so close together for EE? It is understandable that they would be utilized for different cellular companies, but even though they are approximately 100 yards apart, it seems that EE is on both of them.
Christopher_G
Hi @ch1121
Welcome to the community.
If you have a chat with our technical support team, they'll be able to look closely at the masts you're referring to.
What makes you think EE are using  both these sites?
There will be a H&S notice on the cabinets at ground-level identifying the operator for every site.
ch1121
Because I have full cell signal
To have strong indicated coverage within a short distance of a live site is to be expected.
What makes you think both sites are separately EE operated? Check the H&S notices on the ground-level cabinets - are both operated by MBNL/EE?
