iPhone 17 Pro hotspot issues
veronikaburclaf
hi,
i'm having the same issue and i've upgraded to my iphone 17 pro and i cannot hotspot my macbook either. It won't work. Usually from my iPhone 15 i could but ever since my new phone i cannot at all.
Have you found any solution?
thanks
[Mod edit: Added title]
veronikaburclaf
hi,
my hotspot cannot connect to my laptop. My old phone used to be able to connect to my macbook and now i can't connect with my iphone 17 pro.
Please help
Thank you
Veronika
Your posts have been moved to a dedicated thread.
Although as per the posts in the thread you'd added to, are you able to use mobile data functions on your phone directly? In other words,does your phone have a working data connection, and it's just the hotspot that's affected?
