could not use eu data
mumu-123
I am in Austria,but Why I chould not use the EU data. I don't know weather I pay the fee momthly
Does your phone show a connection to any local networks?
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
