What Upload Speed Is The Unlimited No Frills Plan?
Profile closed
Not applicable
Hi, I have EE broadband and want to take out an unlimited sim. This will mostly be used for uploading, so I’m fine with the 10mb speed cap of the cheap no frills plan. However, what is the upload speed limited to? If there’s no cap, then this plan will be sufficient, however I can’t find out what the cap is on the website.
Also, on my other unlimited sim which is 100mb, I tried changing the plan to include EU roaming, and despite it being a 1 month rolling contract, EE say I’m unable to change the plan until after 6 months into the contract. So I don’t want to take the the no frills sim, be disappointed, and then unable to upgrade it for 6 months.
Thanks for your help.
Ritu_D
Hi @Profile closed
Welcome to the community.
The no frills plan has a maximum speed of 10 Mbps, you can view full information here Best SIM Only Deals
In regards to your other Sim only plan, I would recommend speaking with our customer service team as they will be able to do the relevant checks to see if you can increase your plan.
Ritu
Ritu_D
Hi @Profile closed
Ritu
Profile closed
Not applicable
Hi, the page you linked doesn’t specify the download and upload speed of the no frills plan. It just says it’s 10mb. Is the upload soeee 10mb, or is it uncapped? Thanks.
@Profile closed  The maximum you can get is 10 down and up.
Linzi_H
Hi @Profile closed
On the page @Ritu_D has linked above, if you head to the bottom and look at 'The legal bit' you'll see:
No Frills SIM: Includes speeds capped at 10Mbps. As @Chris_B says, this will be for upload and download.
I hope this helps,
Linzi 😊
