Very slow data on unlimited sim
anomander0108
Hi
Wasn't sure to tag this onto another thread or start a new one but couldn't see the exact issue I'm facing so, here we are.
I recently bought a 5g unlimited plan as EE had the best coverage in my area. The speed checked shows excellent outdoor and good indoor.
I am moving house in a few months and thought to go down this route to allow me to get online straight away wherever I next reside and avoid any potential issues that I might have if I took out a fixed line contract.
I use a TP Link Archer NX200 router. It throws out speeds of c.800mbs which is good enough for my needs.
I used a signal checker and it is showing between -32dbm to -40dbm RSSI so, placement is good.
However, I get between 0.40 mbs and 5mbs download speed and slightly more upload.
Faced with these atrocious speeds on 5g, I switched to 4g on the router yesterday and thought I had resolved my issues as I was getting between 70mbs and 120mbs download speed.
With this breakthrough,  I downloaded a 40gb game on xbox and watched streaming tv for the first time in a while.
However, this morning the problem reappeared. Same very slow speeds on 5g, 4g anything I try.
What could be the reason for this? Could I be capped somehow on the amount of data I can use? I notice on my account is states I can gift 120gb but I have none left to gift. Seems suspicious to me if I have unlimited data.
Any advice or thoughts would be greatly appreciated as I have been trying to resolve this for a few weeks now
15 REPLIES 15
Your router's data usage timescale with your EE billing month.
Ok, I understand.
It was set to a default which didn't provide dates. If it's possible to get this info then I will need to dig through the manual to see where it is recorded.
However,  if I have had one day where I've been able to stream an episode of a tv show and download a game that was 40gb, with the rest of the time being a trickle service where I even struggle to load web pages, then I think it's safe to say there is no chance I could have exceeded 600gb. This sim has only ever been used in this router which I bought 2 days before I got the sim.
What EARFCN (for 4G) or NRARFCN (5G) are you connecting to?
The behaviour you're reporting is broadly consistent with being on cell-edge for 5G but having better conditions for 4G. But speeds are primarily dictated by spectrum availability not signal strength - hence asking about carrier IDs.
anomander0108
Hi bristolian
Just checked, had set it to 4g only on router at the EARFCN was 1617. I then flipped it to 5g only and the NRARFCN was 156510.
Honestly,  no idea what these mean so any advice you can offer would be appreciated.
By means of explanation, 4G & 5G services are delivered over multiple frequency bands, each with their own characteristics. In very simple terms, low-bands provide wider area coverage while high-bands provider greater depth of coverage with more bandwidth/spectrum - you therefore need a combination of the two, depending on urban/rural and numerous other factors.
4G-EARFCN-1617 is the standard 20Mhz-wide carrier of 1800Mhz (mid-band).
5G-NRARFCN-156510 is a 10Mhz wide 700Mhz low-band carrier.
Generally speaking, low-bands (4G-800Mhz, 5G-700Mhz) are used as a coverage extension where mid or high-bands (1800Mhz, 2100Mhz, 2600Mhz or 3500Mhz) are not available,
Hence your experience is consistent with being towards the edge of 5G but with good underlying 4G.
anomander0108
Thanks for explaining clearly, I now understand
