Upgraded my plan
Riddick
I have upgraded my phone and plan, it said i have unlimited data for watch, but dont have any network to my watch just connected by Bluetooth, any ideads
Ritu_D
Hi @Riddick
Thanks for your reply.
If your watch was on contract previously this means it was used via a cellular connection.
I would definitely recommend following Chris B's instructions above.
Here is some steps to Set up and Manage your Smartwatch
Ritu
@Riddick  if you have a cellular watch, you need to open the Watch app on your phone and go through the process of setting up a contract for it.  because you’re phone tariff has unlimited data for your watch you will not be charged for the Watch data once you’ve set up the contract
if your watch doesn’t support a cellular connection, then you won’t get one as you need a cellular watch for this.
Well my watch was on a old contract years ago, do I need to call ee.
Ritu_D
Hi @Riddick
Ritu
