Spend Cap
Streetworker01
I’ve just set up a roaming pass for a trip to the USA. Do I need to add a spend cap as well?
Katie_J
Hello @Streetworker01.
Welcome to the community.
You will need to remove your spend cap or set it to allow the charge for your Roaming Pass.
Please also activate roaming before leaving the UK by texting ROAMING to 150.
If you need any help whilst in the USA please be sure to pop back to the community and let us know.
Have a wonderful trip,
Katie 🙂
Katie_J
Katie 🙂
Streetworker01
Thank you. That’s very helpful.
Hello.
do I need a roaming pass £15 to go to the USA
ive txt ROMAING to 150 and am fully set up to roam
I’m on 160mb per month with unlimited calls and txts. Pay monthly.
what is best to do.
thanks amanda
Katie_J
Good morning @Amanda1983J.
This all depends if you wish to use your calls, texts and data whilst in the States.
If you do, you can either pay £2.29 per day to use your services or you can pay for the £15 Roaming Pass which is a 30 day rolling add-on that can be cancelled at any point.
Should you not wish to use mobile data you will be charged local rates for calls and texts.
I hope this helps,
Katie 🙂
