10-08-2023 02:04 AM
I just bought EE SIM then bought package of 25 GB data but mobile data not working... Internet not working...but call & txt massage active...
10-08-2023 07:46 AM
Hi @Ziko3369
Welcome to the community.
Are you in the UK at the moment or abroad? Have you tried restarting your phone?
10-08-2023 10:52 AM
I am in UK ... Tried everything... Reset my phone , reset network setting , reset APN setting also... But nothing... I have 50 GB data... But unable to Internet.. But calling & text OK...
10-08-2023 10:52 AM
10-08-2023 12:01 PM
What kind of device are you using, @Ziko3369?
Is Mobile Data activated in the device settings?
10-08-2023 12:02 PM
Vivo V15
Mobile data on
10-08-2023 12:07 PM
10-08-2023 12:16 PM
It shows 4G but not working..
I am also using another sim called lebara that is working properly. So my device is OK..
10-08-2023 12:19 PM
OK, thanks @Ziko3369
I recommend speaking to our technical support team so they can look into this for you.
