19-09-2025 05:05 PM
I am a very low useer on a stright payg account, using my phone few a very few calls and texts only.. I have £15 credit. Is there any way I can add on a small amount of data for a few days use, say 5 days, as a one off payment. Can this be done and if so at what cost.
19-09-2025 07:53 PM
Did you look under Home > Manage your plan > View add-ons ?
Or text ADD DATA to 150 & select what you want?
19-09-2025 05:16 PM
Please see what add-ons are available here:
https://ee.co.uk/help/mobile/manage-use/pay-as-you-go/get-help-by-texting-150-on-pay-as-you-go
19-09-2025 05:53 PM
@carrotmuseum2 : You may add these data add-ons:
19-09-2025 07:20 PM
19-09-2025 07:53 PM
19-09-2025 08:46 PM
19-09-2025 09:49 PM
If you are getting this info from the ADD DATA text it will be giving you the respective codes to text to 150 to buy them. It will be taken out of your PAYG credit,
20-09-2025 08:22 AM
I see "view your mobile add ons" - select that - Buy Plans and Add Ons - this just gives an info page - https://ee.co.uk/plans-subscriptions/mobile/packs - which is frankly USELESS
So just to confirm - if I text 150 with ADD DATA - I receive a reply giving my options and a relevant for the one I opt for?
20-09-2025 11:31 AM
Hi @carrotmuseum2,
Welcome to the EE Community
Yes the reply will to the text should give you the list of options available to you and then just follow the instructions to reply with the add-on you want to buy and it will deduct it from your existing credit.
Alex
