Roaming in the USA
Lyd3
Hi
EE chat have told me x 3 tines that my account is ready to roam however on the control setting in my EE  account the roaming button won't let me enable it. It keeps saying error. EE assure me it's ok but worrying its not going to work. I fly later.
8 REPLIES 8
Northerner
Hi @Lyd3
What does it say when you text "ROAMING" to 150.
Is international calls and text active? (No from the image).
Lyd3
Its says your device is set up to roam..
Northerner
Hi @@
Can you check for updates to your EE app as it looks like you're on the old app.
Lyd3
Yep it's all updated. Should I uninstall and try again?
Don't worry or bother about the app. If it's doing the same in your online MyEE the issue lies deeper than the app. The app is a red herring.
Lyd3
Yes it's on the online account too. Thanks I'll ring them now.
Same issue as that reported by a few of us here:
https://community.ee.co.uk/t5/My-EE-app-and-website/Bug/m-p/1158319
Just read them all. I rang Customer Services and all they said oh glitch in the system but definitely account is set up for roaming.   Will see tomorrow when I land. Thanks
