10-11-2022 08:48 AM - last edited on 10-11-2022 09:03 AM by Christopher_G
I have paid for the travel pass for XXXXXXXXXXX and XXXXXXXXXXX, however it has stopped working for XXXXXXXXXXX and has no Internet connection I'm in Turkey at the moment and would like this resolved asap
[Mod Edit: Removed mobile numbers from public view]
10-11-2022 09:04 AM
Hi @Kim411
Welcome to the community.
Was the service working originally for the one that isn't working now? Have you tried restarting the phone or manually connecting to an available network?
10-11-2022 11:12 AM - edited 10-11-2022 11:13 AM
Can you make calls & texts?
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
