No internet access
exelanshero
I have not had internet access for about 5 hours, the balance has been added to my number but it still does not connect anywhere, I live abroad and you have been using your service from roaming packages for a long time, right now
[mod edit: please do not post personal information such as phone numbers on the public board. Thanks!]
18 REPLIES 18
James_B
EE Community Manager
Hi @exelanshero,
You'll be able to make calls and send texts, but you'll need to purchase a roaming data add-on to use mobile data.
Abokhalil93
Have you solution???
I cannot buy a roaming add-on because I need to connect to the ee mobile network in order to access the add-on.ee.co.uk site. Where else can I buy it? It does not access the add-on purchasing site from a different network.
James_B
Hi @exelanshero,
The add-on page is zero rated so you should still be able to connect to it.
Alternatively, you can purchase an add-on via the EE app.
Hope this helps.
Maalesef erişim yok , ee mobile İnternet ağında olmadığım için erişim yok , diğer ağlarda bu hatayı veriyor bu yüzden eklenti satın alamıyorum
James_B
What happens when you try to access the page via your EE SIM, @exelanshero?
Did you try using the EE app?
 The application does not work because the mobile data flow of my SIM card is completely cut off, so I cannot access any site on the ee mobile network. Since I am in Turkey, the 150 number cannot be called or messages sent.Where else can I buy add-ons, or can you activate the data roaming setting of my line?
James_B
Have you tried your online account at ee.co.uk or the EE app, @exelanshero?
@exelanshero wrote:
Unfortunately, there is no access, since I am not on the ee mobile Internet network, there is no access, other networks give this error, so I cannot purchase the add-on.
