11-03-2025 06:56 PM - edited 11-03-2025 07:30 PM
National Lottery App and Online
Sign in to the app, try to purchase ticket, tells me "You are Offline"
Re-sign in, re attempt, again signs me out, says I'm offline check Internet.
Tried on Google, done exact same.
My signal is absolutely fine!
My parental access is 18+ too
01-04-2026 05:57 PM
100% It's EE family control causing the issue, I was on 13+ setting and lately NO INTERNET CONNECTION only ever shows! I turned OFF setting and hey presto! I then reset to 13+ and NO INTERNET SHOWS AGAIN ALWAYS, but the problem needs sorting with EE family control background settings as there was never an issue over the years with having setting on 13+. Gambling is on the blocked list for 13+ but the lottery app was never an issue over the years, I prefer to keep it on 13+ so to access app I need to turn WiFi on my pixel 8a and that works ok.
Hope this helps.
29-04-2026 09:06 AM
Agree
This just started up for me a week ago. I checked the Parental Control settings and they were set to moderate which blocked gambling. Removing parental controls solved the issue.
Either the moderate setting has been changed to exclude gambling or more likely EE helpfully changed the setting . I DID NOT change the setting myself.
30-09-2026 01:04 PM
I had the same issue and found through this forum that for some reason my in my EE account parental controls had been set to moderate on my account for my iPhone number, not requested or actioned by myself. After disabling parental controls I could then access The National Lottery App.
