on 05-01-2023 01:16 PM
I need mobile data roaming as its not working outside the house
on 05-01-2023 01:21 PM
Outside which house? Yours in UK? Data roaming is for when you are abroad in foreign lands.
on 05-01-2023 01:23 PM
Hello @Maddy2409 ,
Welcome to the community,
Mobile data roaming is for when you are roaming in another country, this will not help when in the UK.
Have you made sure that you have mobile data enabled and do you have enough data to do so?
You should be able to receive and make calls and send and receive text, just check settings on your phone to make sure that all settings are correct.
What phone do you have?
on 14-05-2023 11:17 AM
Neither is mine 😫😫😫
on 14-05-2023 11:18 AM
Hi. S22
on 14-05-2023 02:12 PM
on 14-05-2023 03:54 PM
Data roaming just means using data over a roaming network - roaming means using your phone outside the UK.
What is the problem you're having?
