London Underground wifi
MitevTM
Hello,
Recently I moved from pay monthly to PAYG plan. Before switching I was able to use EE auto wifi on London underground. After switching I am having troubles connecting to that wifi network. All settings are set as before. I contacted CS and they advised me to use Virgin media network instead. I am finding two networks which are named Virgin media- one is Virgin media, second one is Virgin media WiFi. I can connect to Virgin media WiFi but it refers me to EE auto WiFi which I can't connect,  the other one Virgin media I am not able to connect- it says connection failed.
Any help will be appreciated
9 REPLIES 9
Have you topped up your PAYG account with at least £5 within the last 30 days?
Yes, I have. I topped up £10 pounds 5 days ago and I setup simple payments on subscription pack as well
Christopher_G
Hi @MitevTM
It may be worth speaking to our Mobile Care team so they can check everything from our end for you.
I have spoken to customer service and they advised me to connect to Virgin media wifi, but it doesn't work for me. Shall I  call them again?
Christopher_G
Have you tried forgetting the network and doing it all from scratch, @MitevTM?
Yeah,  I have done it. Restarted after that. Will do it again tonight when go to underground.
Christopher_G
If it still doesn't work, you should speak to our technical support team again so that they can investigate further, @MitevTM.
Keep us posted on what happens.
All sorted. I called CS today and they fix it.
Thanks for your help
Christopher_G
That's brilliant, thanks for coming back to let us know, @MitevTM. 🙂
