I have a Samsung A6 mobile phone. How do I access G4?
Dme2
Matt_124
OP certainly won't be connecting to 5G on a Samsung Galaxy A6 from 2018, but should connect to 4G bands naturally.
@Dme2   What’s G4 ?
It should connect to 4G naturally or even 5G.
Matt_124
OK, I didn't bother investigating the spec of the phone, but I aimed to answer the supposed Q & added an afterthought 😉.
If, by "G4" you mean "4G", this is simply a radio access technology like "2G" or "3G". If your phone has coverage indicators, then you have service and thus very likely 4G.
Does your phone show "VoLTE" next to your coverage indicators? This means "Voice over LTE" which is the technology behind 4G-calling... you're using the 4G network for your voice calls & mobile data if so.
