How can I buy more data?
ivanmichaelovit
I'm running low on data.  How can I buy more?
Thanks!
Evan
16 REPLIES 16
ivanmichaelovit
Hi Leanne 🙂
Thanks for the reply.  I'm struggling with the same issue.  About to run out of data, early, can't see how I can just give you some money and buy some data.    Have looked at the links but neither is clear what happens.  What I need is a button that says "buy nGB here for £n.".  /or/ an explanation as to whether a new pack can start before 30 days.  As it is the system suggests I'll be out of data in a couple of days and will then have to wait another two weeks before I cam get any more.  I can't believe this is correct but don't want to find out in the middle of an important meeting.
So, it terms amenable to the /meanest/ understanding - how can I buy more data?
Thanks!
Evan
@ivanmichaelovit : You can make a new pack start before the old 1 expires w/out having to wait by texting NOW to 150 after buying the new pack.
If you rather buy a data add-on look at http://add-on.ee.co.uk/purchase when not connected to WiFi to see what data add-ons are available.
Boris27
This is crap - that link to Add-on tells me I don’t have access!
James_B
EE Community Manager
Hi @Boris27,
Are you accessing the link over mobile data (via the mobile device you need to buy data for), rather than a WiFi connection?
digitaldavid1
How annoying that you can't buy more data. I have turned off WiFi and cannot access.
James_B
Hi @digitaldavid1,
What happens when you try to access the add-on page?
@digitaldavid1 , @Boris27 : Try clearing your browser's cache & cookies.
Link not acceptable - forbidden
