Gifted data
flash70
Why am I getting a notification saying iv used 80%of my gifted data ? I use my hotspot for my Xbox and was assured I had no limits on doing this at time of taking out this contract
EssexBoyEE
If you do not Gift your Data to another Device (ie, another Phone Number on your Account) then just ignore the 80%  Message, it has nothing to do with you Tethering or Hotspoting your Data.
@flash70   The first 120 Gb of your allowances is what you can gift data from.  The thing is your are going to use that if you don’t gift it so you’ve got a notification telling you of that.
EssexBoyEE
