05-03-2024 08:33 AM
I've been using EE for a while and now it has blocked one of my manga sites, previously it was working, but recently it seems like they had blocked it off. The website is still accessible only if I use WiFi.
What can I do?
05-03-2024 10:05 AM
Hi @ima_genie
Thanks for coming here.
Could you check your content settings in your EE account, is this set to off?
Our How Do I Turn On Parental Controls on My Device?, Help page has information on how to check and change your content lock settings.
05-03-2024 11:03 AM
I can't find this anywhere in my settings, additionally this is a single plan account. My parents don't even use EE
I'm confused as to why EE would suddenly add content blocking when I've been using it for over 2 years without it.
05-03-2024 11:08 AM
Hi @ima_genie
Parental controls is the content lock settings and is used to block 18-rated content, this doesn't mean you have any one else on the account.
If you call us on 150 the team can check your settings to see if anything has changed and help you with the site you are unable to access.
05-03-2024 01:10 PM
Are you on contract or PAYG?
06-03-2024 07:59 AM
Then please explain why this was added after 2 years of using the same card, same account and same number
06-03-2024 08:25 AM
