02-08-2023 03:30 PM
I have a new EE contract data SIM. I am trying to use it in a Celerway Go portable router. The router recognises the SIM, configures itself with what looks to be the correct settings (APN=everywhere), but the status never gets beyond 'connecting'.
An O2 data SIM in the same router works fine. This EE data SIM works fine in other routers, so the SIM itself appears to be fine. I have another EE data SIM which also works fine in other devices, but also doesn't connect if put in the Celerway Go. Swapping SIM slots doesn't help.
Any ideas? I'm about to give up on EE and try another network.
02-08-2023 05:37 PM
Hi @Bobtheknobs
Thanks for coming here.
Does the router support iPV6?
If no other EE SIM card is working, have you tried contacting the manufacturer to see if EE is compatible with this router?
03-08-2023 10:49 AM
Hi Leanne,
Thanks for the reply. Yes, the router is iPV6 compatible, and I'm aware of other EE SIMs working (the company that sold me the router have one working, and they just inserted it and it worked first time). I've just tried a third EE SIM here with the same result. These EE SIMs are ordered via our company agent, but they work fine elsewhere.
Bob
03-08-2023 10:54 AM - edited 03-08-2023 10:54 AM
Thanks @Bobtheknobs
In this case, please report this to our tech gurus or via your company so this can be looked into.
03-08-2023 11:45 AM
I tried ringing the EE Helpline but they didn't recognise either the SIM number or the phone number, so couldn't progress it! I don't think I'll get anywhere reporting the issue back through my company, as essentially the SIM is working. It just seems to be some strange incompatibility with these SIMs and the router. Probably just a config tweak needed, but it's knowing what to tweak.
I have also registered the query with the router manufacturer (trying all angles!).
Bob
03-08-2023 12:59 PM
Is the SIM part of the business contract with your company? @Bobtheknobs
03-08-2023 03:31 PM
I would imagine so, yes.
03-08-2023 03:33 PM
Thanks @Bobtheknobs
If you speak to your company agent who provided the SIM, they can contact EE and let them know what is happening to see if anything is needed to be changed.
07-08-2023 06:48 PM
One other user of the Celerway Go has found that his PAYG SIM works fine, but as mentioned mine doesn't. Comparing the two, the settings are below (all autoconfigured). Would you expect the differences seen here?
My Contract SIM:
ICCID belongs to Mobile World (MVNO of T-Mobile)
IMSI used is:
Network operator: Everything Everywhere Ltd
Network name: T-Mobile UK
PAYG SIM:
ICCID belongs to IDT Mobile (MVNO of Orange).
IMSI used is:
Network operator: Orange PCS Ltd
Network name: Orange
08-08-2023 07:48 AM
Hi @Bobtheknobs
Are you able to change the settings? We have a EE APN Settings: Where to find them article that may be of help to you.
