Dual sim
Jamieh187
I was looking at getting a second sim on my 15 pro max to seperate work and personal, with the new sim being my new personal number and original sim being my business number, is it possible to set up so the unlimited data on my original plan will be used across both sims? Basically so I dont have to spend a lot of money on a new plan with unlimited data as I use ALOT of internet during work and personal time.
But still they are on separate EE a/c's. Your personal no. is on an EE personal a/c & your business no. is on an EE business a/c. You can't share data across 2 EE a/c's.
Northerner
Hi @Jamieh187
Are you the business owner?
If not then no you cannot share data.
@Jamieh187 : You can't share data across 2 EE a/c's, your no. being on your own a/c & the business no. being on the business owner's a/c.
Yes I own and run my own heating business
