Data
Tashin1100
I recently got 100GB of data but when I turn on Mobile data 4G pops up but nothing works. Cant message anyone use maps or search anything up
[Mod edit: Image rejected due to it containing personal information.]
1 ACCEPTED SOLUTION
EssexBoyEE
Have you swopped Sims recently from another Network in the Phone?
Check your Mobile Data APN Settings are correct, should be APN Name = everywhere
EssexBoyEE
Yes I have swapped.How do you check this APN setting
What's the Phone model
Abdull2
Same
Leanne_T
Hi @Abdull2
Thanks for coming here.
How much data do you have remaining from your allowance?
What device are you using?
