Data
Olliehargreaves
I currently have 100g of data a month, how would I go about making this lower like 40
1 ACCEPTED SOLUTION
Alex_M
Star Contributor
Star Contributor
Hi @Olliehargreaves,
Providing that you are not currently in a fixed term contract, you should be able to upgrade by visiting https://ee.co.uk/app/upgrade-hub
Simply choose a sim-only plan with a lower data amount and complete the upgrade.
If you are in the middle of your contract then you won't be able to change your plan without paying an upgrade fee first.
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
Alex_M
Star Contributor
Star Contributor
Thanks,
Alex
