Data not working
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-09-2024 03:48 PM
I bought an 8g data plan but I’m not getting connected
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-09-2024 04:34 PM
Does your phone show network coverage? Can you make & receive calls? Are you in the UK or abroad? Is mobile data enabled on your phone? Have you been able to use mobile data in the past?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-09-2024 05:40 PM
First time using data on this phone in the uk,iPhone shows signal but only able to text 150 no I message. Data Is on in control center
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-09-2024 05:42 PM
"First time using this phone" implies that you're an existing EE user who's upgraded from a previous phone, is that right? And if so - are you using the same SIM as was (presumably) working in your old phone?
The more detail you can give, the easier it is for others to help/advise. There's no limit on the length of replies.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-09-2024 05:52 PM
I have had data on as part of someone else’s contract on a different phone. Now I have a new sim on a new phone that came empty giving my new number
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-09-2024 02:25 PM
Hi @Ned7.
Did you receive this phone as part of an upgrade or a new connection?
Is the contract under your name now?
Speak soon,
Katie
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-09-2024 04:18 PM
Yes it under my name and was not part of any previous deal.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-09-2024 05:56 PM
@Ned7 Just to clarify as you mentioned specifically iMessage not working, it is not just iMessage but all data that is not working, so you cannot load BBC - Home for example is that right?
If calls and texts are working ok and it is just all data that is not working, there are a few things to check. If you are a contract customer first login to your EE app and select Manage> Settings and make sure Use mobile data is enabled here which will confirm there is no block network side.
On your phone go into Settings> Mobile data and make sure the apps you are wanting to use are enabled for mobile data.
Check you have no VPN or configuration profile active in Settings> General> VPN and device management
Also if you have not already done it since the issue started, try giving the phone a restart.
Alex
- Phone won't work unless its connected to wifi in Mobile Network discussions
- I need to make a data gift urgently on my app but it won’t let me in Mobile Data
- Coverage in Darlington in Mobile Network discussions
- Images/videos not loading on social media sites in Mobile Data
- Query re data -roaming inside EU in Roaming
