Data not working on iphone
js6321
I am abroad using my ee data and i have brought £10 of 3GB add on for 7 days but its not working i have also recived the confirmation also and i topped up, i am also staying in denmark at the moment.
Any Suggestions? Need Help.
12 REPLIES 12
Schockwave
@js6321 , have a look here about roaming if you have not already done so:
https://ee.co.uk/help/mobile/roaming/roaming-costs
Have you rebooted your phone and do you have signal showing on your phone?
Did you receive a welcome message?
Yes i have rebooted my phone still nothing.
And yes it showing signal and yes i did recevie a welcome message
James_B
EE Community Manager
Which add-on did you purchase, @js6321?
Thank you for getting an add-on. You now have £0.00 credit. To check your allowances reply AL. When you want to top up go to ee.co.uk/myee or call 150
James_B
Hi @js6321,
If it was a UK data add-on you purchased, you'll also need to purchase an EU roaming add-on to use it outside of the UK.
Schockwave
@js6321 , You need to look at the page I gave you the link for roaming, it will tell you what the costs are. The top up is for UK, different from roaming.
I did that its just not working shluld be automatically
Welcome to Denmark. There may be a charge to access to your pack allowances, Free Boost or add-on while you're here.
It will cost £2.50 for 24 hours access or you can choose to pay £10.00 for 7 days access. If you're in Ireland these charges do not apply.
Schockwave
@js6321 , have you got signal, could you check that signal is showing on your device? You may need to manually search for a signal, as that could be the reason, possibly.
