Data SIM
Paullec
I have a data only card for my car live options, traffic,. weather etc.  Is there a way to check the balance of data  before I buy another ? , I thought 120gb would last a bit longer than a few months .
@Paullec   That 120Gb might only have a use by date.  Ie 3 or 6 months not necessarily until used up.
easiest way to check how much data you’ve got left on it will be to put that Sim card into a phone and text balance to 150.  Or log into the account that you will have and see what’s on there.
I'll try the phone way, thanks .  I don't have a account for this, Was purchased from a newsagent and just put in car.
Look at http://add-on.ee.co.uk/status when not connected to WiFi to see data & credit status.
You don't need to keep buying new ones. You can add more data when it's run out.
